Search instead for
Might be a daft question - splitting out systems manager
Hi there Guys and Girls
This may be a silly question but if I have a system manager within a network, does anyone know how I can remove this and put it in its own network ?
-Gary
Accepted Solutions
Re: Might be a daft question - splitting out systems manager
Go:
Organization/Overview
Click the "arrow" network to the networks tab to make it use most of the screen.  Select the network and then go "Split".  You can then re-combine the bits you want back together.
4 REPLIES 4
We have our systems manager stuff in its own dedicated network.
Go:
Thanks, that worked, all be it, a little long-winded :-)
Adam, thats what I had and combined it into another one in error and then could not see how to split it again :-)
