Search instead for
Combine two locations into one
I have two separate locations, under one dashboard, each using a single MX64W.  I'd like to treat it as one network with shared group policies, security and same devices between locations etc. - simply management across both locations.  There are no VPNs or connectivity set up other than internet at each location.
As you can tell I'm a novice and couldn't find anything that walked me through how to do this.
Thanks for any help.
Accepted Solutions
Re: Combine two locations into one
you cant have 2 mx in one network other then active/standby mode.  you could look at the possibility of a using template and bind both networks to the template.
https://documentation.meraki.com/zGeneral_Administration/Templates_and_Config_Sync/Managing_Multiple...
3 REPLIES 3
Hi @SBMMKL
@ww  is correct, but maybe you use the VPN tunnel to concentrate all your traffic from MX2 to MX1 and manage your devices and plolices in your "main" MX1.
cheers
Thank you, just applied it and works great - very easy - just what I was looking for.
Steve
