Solved! Go to Solution.
Thanks @MerakiJockey505 I've tried that already but that will only show me events for the network, I was looking for clients list older than 30 days. I found out that 30 days is the maximum time you can obtain.
Good morning orange-is-black,
I believe you can check out older clinets using the event log. Under Network-wide > Monitor > Event Log and then used the Before fields and specify a date and time. Let me know if this works for ya. 🙂
At the top next to Event Log if you select "for security appliances" on the pulldown and use the specific date info, the client will appear in one of the columns. Are you looking for a specific metric?
Hi @Bruce - I was just trying to get a list of clients that connected to our network since we deployed 4 months ago.
