I'm currently working on a task to calculate the connectivity on the dashboard and integrate it to a report. I've found that those are events on the event log. Actually my options to get the data are three:
Download the full log, which I didn't found a way to download it to process the data outside of the cloud different from a syslog.
Use a syslog to capture the events. I don't consider this one as it involves another element (the syslog server) and add a step of complexity to the solution.
Find a different way to receive the events from all the equipments. Which for me is discarded as there is no away to get this from the API.
I'm reaching this forum in case anyone else have found a different solution or any previous experience you can share to give advice.
Thank you,
