Base Configuration Style Template?
TimBisel
So maybe I am missing something with the templates. But while the bound template options is nice, is there more of a template for a base config to build from instead of the bonded group config style that I currently see? Really only have the configuration in the MX is all we need to use from network to network with everything else in the area being pretty unique from site to site. Don't get me wrong the bonded function is really nice, but just not what I need at the moment.
1 REPLY 1
jdsilva
You use the clone from option when creating a new network instead of binding. This way you can copy all the base settings form an empty network, or from a template, and then customize after as you see fit.
