Request all devices in a network results in an empty array
LairdTurner
I've tried make a request like
https://api.meraki.com/api/v1/networks/{networkid}/devices
As a response I always get an empty array, but in the dashboard there are 30 devices associated with the network
with the uses network id?
What could be wrong?
Thanks!
7 Replies 7
you run it from where and with what code?
could you try run it from this site
https://developer.cisco.com/meraki/api-v1/#!get-network-devices
LairdTurner
If I run it from the delevoper site I get the same response.
200 - empty array in body
Can you verify the network id is correct?
https://developer.cisco.com/meraki/api-v1/#!get-organization-networks
Does this give output of the device  and network?
https://developer.cisco.com/meraki/api-v1/#!get-organization-devices
LairdTurner
Hi!
Yes, I can verify that my used network id is correct but when I'm try to get the organization devices via
I get 200 and a empty array!?
I just noticed  you posted in mdm.
The api you trying is for network devices.
Try this
https://developer.cisco.com/meraki/api-v1/#!get-network-sm-devices
LairdTurner
Oh! Shame on me!
This have worked! I don't have cared that I must make a request from / for the devices of the systems manager!
Thanks!
Inderdeep
@LairdTurner : What error message you get as you are running the correct API call !
Regards/Inder
www.thenetworkdna.com
