Legacy Enrollment failing
NZRunner
I am trying to enroll a Windows 10 Home machine in a Legacy Meraki account. Installing the agent appears to work as the service is running, but the machine never appears in the client list.
If I navigate to http://m.meraki.com and enter the Network ID, it flashes up and says "Found: Company Name" but then comes up with a screen that says: -
You must install the Meraki Systems Manager desktop agent!
Anyone got any thoughts on why it can correctly find the network but then immediately tell me I need to install the Systems Manager Agent?
Note, I have disabled the firewall to ensure it is not blocking the agent.
6 REPLIES 6
Re: Legacy Enrollment failing
Try downloading the agent manually from the Dashboard and then installing it.  I would also "right click/run as administrator" on it.
NZRunner
Thanks for the suggestions.
I have tried both of those although I don't get a "Run as Administrator" option when I right-click on the MSI that is downloaded.
Does Add/Remove programs show the agent as being installed?
Do you see the agent running in Task Manager?
I've never tried using it on a "Home" edition of windows.  I guess it is possible that something is missing from this edition that the Meraki agent needs.
NZRunner
Yes to both your questions.
It has been running on this machine previously. I noticed it wasn't working recently, so uninstalled and reinstalled the agent but to date, I have not been able to get it running properly again.
In addition, I have noticed that other clients (Windows and iOS) in the organisation are not updating the internal IP address correctly.
I am beginning to think it is a Legacy issue, but with no support from Cisco, I have no way of telling.
NZRunner
And to further support my suspicion that Cisco is starting to wind up the legacy product, if I try to Enroll the Device using the option available in Windows 10 Settings, I get a message that tells me "Enrollment Disabled", as shown in the screenshot below: -
NZRunner
This has been dormant for a while, but thought I would post the solution to my issue in case it helps anyone else.
Basically, there is a known incompatibility between AVG Anti-Virus and Meraki. AVG has no plans to change that. The following quote is from an Avast employee (they now own AVG): -
"It's not possible to whitelist such traffic at the moment so we don't recommend using AVG and "Meraki" together. Thank you for your understanding!"
You can read more here: -
https://support.avg.com/answers?id=9060N000000UDFYQA4
I have confirmed this by uninstalling AVG from two VM's and Meraki then works perfectly. I note, it must be uninstalled, disabling it is not enough.
