Feature Request: Ability to Create the Same Profiles from Server in Meraki
jared_f
I am aware that you can download profiles you create in OSX Server and upload them to Meraki, but this is extremely difficult to track versions. I invite others to wish that the full suite of profiles was available to admins. If this is already in the works, I can't wait lol!
Thanks!
1 REPLY 1
sshort
Yep. Apple will add even more MDM configurable options in High Sierra 10.13.4, including the ability to defer software updates by X days.
The feature I would really love to have is the FileVault personal recovery key escrow. You can create that right now in Profile Manager, but it won't work because that's assuming you have a on-prem solution using macOS Server for MDM vs Meraki.
