Disable S/MIME
NikKare-Ariki
Disable S/MIME
How do we disable S/Mime in an Active Sync profile.
On my Active Sync Settings page there are boxes for Enable S/MIME Message Signing, and Enable S/MIME Message Encryption, but we can't disable S/MIME Completely.
On our iOS Devices our staff can't disable it manually as it is a setting of the profile.
4 REPLIES 4
BlakeRichardson
Re: Disable S/MIME
Hi @NikKare-Ariki Does this help?
NikKare-Ariki
Re: Disable S/MIME
Hi Blake,
Thanks for the quick reply.
We already have all of the S/MIME Options on the profile disabled, and on an iOS Device it is still enabled and can't be disabled.
N
BlakeRichardson
Re: Disable S/MIME
Hmm, have you tried enabling it via meraki and then disabling it, maybe it needs a kick from Meraki to get itself in order.
Will_Caldwell
Re: Disable S/MIME
So I just had this issue as well.
Meraki acknowledged that the profile was corrupt and would have to be abandoned.
Copies of the profile would also exhibit the same behaviour and could not be used.
I created a new Active Sync profile from scratch and the S/MIME was off when applied.
Good luck!
