Hi
I have set all device names in the MDM but all the iPads are still called iPad on the device.
Are you aloud spaces and - in the device names?
Also can you make the device name and serial show on the desktop.
Solved! Go to Solution.
@Koops you need to enable the below setting which is located under the restrictions payload located in Systems Manager > Settings
@Koops : check this thread May be helps you
Thanks for your advise but i have not fixed this yet and all my iPads are still named iPad.
People changed the name of the ipads. Check this thread
Thanks I have this working now.
