API for Endpoint Management?
MichelRueger
Hi All,
I just wondering if somebody is using the API for SM?
The amount of possible API are very limited.
I am looking for a solution to add a new APP to a Profile true API?
If somebody has a idea let me know
Thanks Michel Rueger
3 REPLIES 3
vassallon
@MichelRueger Looking at what the API can do I don't see any way to add an App through the API.
https://developer.cisco.com/meraki/api
jm_peterson
@MichelRueger As it stands now the api is limited in that sense and you cannot manipulate custom profiles. It seems the functionality is limited to what you can edit if you clicked on a device(s) page in Systems Manager, or return data on all the clients on a SM network.
I have used it extensively for those tasks if you need any additional information.
mattia
this would be an interesting feature request
