iOS managed browser solution in SM?
WilliamDB
Is there a solution for a managed browser such as "intune managed Browser" in Meraki SM for iOS devices?
I want to be able to set bookmarks and use this app as a single app.
It is not possible with Safari or Chrome I read.
Does anyone have sugestions?
BrechtSchamp
Well single app mode is possible with Safari but I'm not sure if you'll be able to set bookmarks. If you can it'll have to be via managed app settings:
https://documentation.meraki.com/SM/Profiles_and_Settings/Using_the_Managed_App_Settings_Payload
However maybe you can take a look at an app specifically designed for this purpose:
https://www.kioskproapp.com/
I have no affiliation with Kiosk Pro, and I haven't tested it so it may or may not be crap.
@WilliamDB How many bookmarks do you need to setup?
You can do this with Chrome on Android using Systems Manager.  Never tried on iOS but don't see why it wouldn't work.
This previous post seems to have quite a bit of info on doing this.
https://community.meraki.com/t5/Endpoint-Management-Systems/Android-Google-Chrome-Managed-App-Config...
