Profiles not copying over
vassallon
Just curious to see if anyone else is having issues with profiles copying over between networks. This has always worked in the past up until the recent changes in Dashboard.
Profile to copy overProfile to copy overCopied profile in new networkCopied profile in new network
No I don't mind re-adding all of the setup I have done in the other network but I'd much rather it just work as intended. I have opened a case already but thought I would see if anyone is experiencing this behavior.
PatrickL
Meraki Alumni (Retired)
Hey everyone - this is a bug and not expected behavior that we're looking into. Thanks for the heads up!
7 REPLIES 7
Mark24
I just noticed the same thing today.
Profiles with Wifi Settings seem to work but profiles with iOS Restrictions will not copy.
Yup same thing here ,, @Melissa is this a Bug in Meraki or a limitation ?
@MikeMandalorian I'm sure hoping it's a bug, because if this is now the "new" version is going to work. I want the old one back. I much rather would be able to copy profiles then having to build them by hand for every single network when we make a change.
PatrickL
PatrickL
Should be resolved now.
vassallon
@PatrickL I just tried it again and received the following message.
vassallon
I just tried it again this morning and the profile copy is working correctly.
