I'm trying to prevent additional accounts being added to the Outlook iOS app.
I can't see a way to stop users adding extra accounts, other than the main configured one. Is there a way to do this, and if not, is there a mail app that can do this?
Thanks in advance,
Paul
Solved! Go to Solution.
Found it! If anyone's looking to do the same, the settings that worked for me are:
IntuneMAMAllowedAccountsOnly - Enabled
IntuneMAMUPN - user@yourcompany.com
These work for me, and prevent additional accounts being added to Outlook.
If it's possible in Outlook for iOS you would find the exact preference key here: https://docs.microsoft.com/en-us/exchange/clients-and-mobile-in-exchange-online/outlook-for-ios-and-...
Then create a custom/managed config profile for iOS in Meraki
Thanks, sshort!
I've looked at that page before, but couldn't see any option for limiting accounts. I think I must be overlooking something, as something simple as that, I'd expect to be pretty standard?
I'll continue digging into it and if no joy, just ditch Outlook app and try something else.
Thanks again!
In your Profiles, one of the settings is "Managed App config". From there, select Outlook and put in the keys above.
A link to the Managed App Config guide is https://documentation.meraki.com/SM/Profiles_and_Settings/Using_the_Managed_App_Settings_Payload
