OS Update Command broken?
BlakeRichardson
Just want to confirm is the update OS command broken for iOS devices, I have a stack of devices I want to update and the command just sits in the  activity log "pending"
I have the device in front of my unlocked as well and have confirmed there is no popups or anything on the device.
Devices are all supervised devices loaded via DEP.
1 Reply 1
Kevin_C
Hi @BlakeRichardson,
At this time, There are no known issues with the OS update command.  A couple of things to check:
- Check the battery level on devices.  Charge devices to over 80%.
- Check the storage capacity on the device.  If devices are running low on storage, remove apps to reclaim storage space.
- If using Shared iPad, ensure that user accounts are fully logged out on the device.
If you continue to have problems, please open a case with our support team so that a specialist can collect logs and help you troubleshoot your issue.
