Modify / Rename Tags
Hello, I try to rename an owner tags, but I can't found the tips !!
4 REPLIES 4
Re: Modify / Rename Tags
Hi
You can rename tags by browsing to Systems Manager>Tags  select the tag and click edit to changethe name.
Hello, you have a screencapture ? I don't found edit button.
Step 1 click on the tag you wish to modify on the lefthand column.
Step 2 click edit.
@Alex69
All you should have to do is going to the owners list and from there click on the drop down for tags or click on the owner and make the necessary changes. Do remember to click save once you are done as well.
