Meraki Systems Manager and Cisco Umbrella Roaming Client
anthonyjgates
Hello everyone,
My team and I are currently working through some R&D for a potential large scale SM deployment.
Does anyone know if you can "push" the Cisco Umbrella Roaming client / agent through Meraki Systems Manager? We are aware of the Umbrella integration with SM for supervised iOS devices, but are more concerned with laptops (PC), macbooks, and Android tablets.
This customer does not have all devices on a DC, so AD integration is not the fit, and they do not have Any Connect.
Hope you all are killing it out there, and I appreciate any insight you may have.
kYutobi
Why not just install the umbrella client for the windows machines and macs. You can have a policy set for them as "Roaming clients" and put them in there.
Enthusiast
2 REPLIES 2
kYutobi
Enthusiast
SoCalRacer
I didn't think Umbrella supported Android devices with a client. I believe you could point the DNS to umbrellas servers with a policy.
Also no mention here.
https://docs.umbrella.com/deployment-umbrella/docs/2-prerequisites-update
Windows and Mac devices you should be able to download the installers and follow below for help pushing.
https://documentation.meraki.com/SM/Apps_and_Software/Installing_Custom_Apps_on_Windows_and_Mac_Devi...
