Disable settings app IOS
Merijn
Is it possible to disable or protect the settings app?
Our ipads are with DEP but after al the restrictions the settings app is still available for the users.
Regards,
Merijn
6 REPLIES 6
jared_f
That is not possible (even with a blacklist iOS will ignore it and still show it). You can restrict a lot of what is showing in settings with restriction profiles.
Jared
@Merijn What are your trying to achieve exactly. Is there someting certain you are trying to stop.
@BlakeRichardson I want to disable the option to reset the device. After all the restrictions there is still a reset option available.
@Merijn you can stop users doing that, if you setup a restriction setting you just untick the below option.
@BlakeRichardson i indeed disabled this option but the users have still a basic reset option. (That resets the wifi settings and such). But i didn't find anything that disabled all the reset options.
@Merijn sorry I missunderstood you there.
