Ip's internally via Mac
213chrisp
I am trying to do some port fowarding to a 3d printer i own to allow remote access , but i am struggling to get the gx20 to actually hold internal ip reservations via mac address.
I have added a internal ip to 192.168.128.22 via my mac, which i have confirmed the mac address is correct in 3 different locations to make sure it was proper,
Worked fine lastnight, but this morning it had reassigned the ip address to now be .29.
I know i have rules to reserve the IP , i have port foward set to the .22 ip block. everything seems correct, but it didnt hold.
Am i missing something?
1 Reply 1
Xydocq
Hello 213chrisp
Did you set the adress reservation under Networks -> Default -> reserved IP adresses? Or did you just set the adress to be excluded from DHCP?
If a fixed adress isn't working for you. Set the printer to have a static IP and exclude the IP from DHCP.
Hope it will help.
