Search instead for
Disabling devices or an entire network
We think it would be helpful to be able to disable a particular device or even an entire network using the Meraki Dashboard.
Use of this feature would be limited to where a customer was in breach of our terms and conditions, specifically not paying the monthly amount for the managed service (including the rental of the devices concerned).
Is there any support for such a feature amongst other MSP's here.
Do you have any suggestions as to how we can effectively disable a device using the dashboard as it is?
3 REPLIES 3
Re: Disabling devices or an entire network
You just move the device out of the network. To enable it move it back into the network.
AKA - "doing the hokey cokey"
I'm sure you could probably pretty easily throw in a firewall rule to do this as well.  No idea if something like this would work but it should shut down their internet.  Or could also maybe do something on the switches pretty easily if they are L3.  Source would be clients LAN destination internet. I'm just not sure if this would stop the devices from talking to the Meraki cloud as well.  Hopefully the Meraki devices are smart enough to not do that but I've never tested it.
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
