Insight - cant see option of License
MAzad
Can someone please explain to me why I cannot see the License option under Insight? The Insight license has been added.
Thanks,
Mariam
2 Replies 2
BlakeRichardson
@MAzad  Have you clicked on the licenses tab on that window. Your Insight layout looks very different to mine.
Ryan_Miles
your org is using per device licensing. you should see your MI licenses (and all licenses) under Organization / License Info. you would assign your MI license using the license tab there.
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
