Hi. A couple of weeks ago my organisation tab disappeared from the SM dashboard. Any help getting it back would be much appreciated as the certificate runs out in about 10 days.
Are you the only admin? If not I suspect another admin has removed your organisation rights. This would usually be done in the case of your have a junior team member who you want to be able to make network changes but not add or remove admins, manage licensing or inventory.
Ha - Thank you so much - although your answer wasn't spot on it was enough to make me rummage and I found I hadn't given myself organisation rights as me - although I had them as the original admins (also me!)
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
LITHIUM.Form.resetFieldForFocusFound();
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_32fedce5a9593b","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_32fedce5a9593b_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_32fedce5a9593b_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_32fedce5a9593b_2","feedbackSelector":".InfoMessage"});
LITHIUM.AjaxFeedback(".lia-inline-ajax-feedback", "LITHIUM:hideAjaxFeedback", ".lia-inline-ajax-feedback-persist");
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_32fedce5a9593b","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
