I manage over 200 Ipads with Meraki MDM and we were given access to a School systems WIfi couple years ago. They created a Custom UN/PW for me to preset in Meraki and provided a Cert. that is updated Biyearly. Generally this works flawlessly but every now and then it seems to break for a couple Ipads(different each time) and i have to either goto the School where a staff member is and put in on a hotspot update the profile or bring it back to the office and wipe/reload it. The school systems uses Aruba for their AP's.
@MikeMandalorian is the Wifi profile deployed with other settings in the same profile?
I have found best practise is to have wifi and other settings seperated otherwise each time you make changes it has to push EVERYTHING in the profile including the WIFI info which can break the connection requiring manual intervention.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6748388843515b","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6748388843515b_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6748388843515b_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6748388843515b_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6748388124acec","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
