Unable to clear Activation Lock on iPad
vassallon
Came across this message today which was brand new and support is already aware of the issue. I wanted to share it here in case anyone else is seeing it.
When clicking the button for clear activation lock on an iPad you receive the following error:
Error - SSL_connect returned=1 errno=0 state=error: certificate verify failed
vassallon
Got an email from Meraki support and this issue is now fixed. I just tested it and verified that I am now able to clear activation locks.
My gut feeling is that Apple changed how Meraki needed to submit the request and it took some interaction between the two to fix the command to clear activation locks.
2 REPLIES 2
Drew325
I saw that this morning as well. I'd be interested in what support has to say about it.
vassallon
