Unable to add tag in Meraki MDM
AndyTheIdiot
Literally the title.
I go to add a tag, and the "continue" is greyed out. When hovering over the button, the cursor becomes a "No Entry" type symbol.
Is this a licencing thing? Is it just broken for me? What have I done wrong?
Thanks.
5 REPLIES 5
BrechtSchamp
The continue button becomes available once you select a device. In your case it seems like you don't have any devices yet?
Before selecting a deviceBefore selecting a deviceAfter selecting a deviceAfter selecting a device
Thanks for the advice, BrechtSchamp, but we have a lot of devices.
I suspect it's because we are on the Legacy version. Without being licensed, I can't see the devices in the list.
I'll continue chasing the bosses for mo' money!
Ah, that'll be it!
Yip its because you are using the free version, your initial screenshot actually mentions that.
AndyTheIdiot
For reference, we think we've found a work around for the time being.
Select a device and click Edit Details -
Under the Tags section, type in a new tag and click the "Create" option -
This new tag will now be available to all devices, but you will need to 'manually' add the tag to each device that needs it, as you cannot access the list due to the license restriction.
Let hope this helps other folks whose bosses moan about spending too much money!
