Unable to add multiple apps to dock
dnitzel
I'm setting up the Home Screen for a cart of iPads and the teachers requested that I put a couple of apps in the dock.  I was able to put the two apps in the dock within Meraki, but only one of them ends up on the iPad. (The last one I added to the dock).  Is there something I need to do in order for the 2nd app to appear in the dock?
2 REPLIES 2
BlakeRichardson
@dnitzel Have you scoped the apps to load onto the devices using the Systems Manager > Apps page?
Are you using VPP to purchase licenses for your apps?
Yes
