Hello-
If I remove a tag from an a custom Enterprise app, will that uninstall the app from the device? These are supervised iOS devices.
Thanks!
Solved! Go to Solution.
Sorry, I was making the assumption that would be checked. If it is not checked then it would not uninstall. It would also not install it automatically, the user would need to download it manually from the App Store or from within the "Meraki MDM" app.
Yes, as long as you have it set up to install on the iPad based on that tag.
What if the "Auto Install/Uninstall" option in unchecked?
@MacuserJim wrote:Sorry, I was making the assumption that would be checked. If it is not checked then it would not uninstall. It would also not install it automatically, the user would need to download it manually from the App Store or from within the "Meraki MDM" app.
Okay, that's what I thought. Thanks for the information!
