Set Dock on Macs
jared_f
Set Dock on Macs
Hi Folks,
I found this great website that allows you to configure docks for Macs. It allows you to place links to network shares and websites also. Just in case someone else is interested in doing the same.
http://techion.com.au/blog/2015/4/28/dock-master
Jared
MRCUR
I've used this in the past and it's absolutely fantastic!
MRCUR | CMNO #12
jared_f
@MRCUR It is great. I used to push dock items with a package, but the user could remove them and I would have to manually re-push to them.
sshort
Yep, that's a great resource that creates an awesome pkg that I push out. When I tried to build a dock profile manually I kept having issues with the Downloads folder populating with the ? icon, or Downloads resetting the Finder window view preferences after reboot.
