SM and MX65X
SM and MX65X
As mentioned before, I'm also interested in using SM for private (family) use.
So today I started my Free 30 days trial.
My question is: are all the functions available for every system?
My setup us: MX65W - MR30H and MS220-8 switch.
Tried this, in a new profile:
https://documentation.meraki.com/SM/Other_Topics/Using_Fast_Lane_with_Systems_Manager
  1. Click + Add Settings and select WiFi to create a wireless payload.
    But I do not have the Wifi symbol, only "Restrictions" and "More iOS"
Second question, is the price of SM affordable for private use ?
Many thanks,
LD
Accepted Solutions
Re: SM and MX65X
I think you need to be using the standalone access points like the MR33 to use Fast Lane.
6 REPLIES 6
Re: SM and MX65X
Re: SM and MX65X
System Manager licenses RRP is around $40 USD per year. A great and highly recommended addition if you already have a Meraki network.
Re: SM and MX65X
Thanks!
Maybe a. MR33 in 2018.....
LD
Re: SM and MX65X
If Meraki is out of your price point, take a look at Jamf Now. I try not to advertise other products on forums, but it is understandable that you are looking for a home use management that is not a lot of money.
Re: SM and MX65X
As a side note, it does not have nearly the management feature that Meraki has!
Re: SM and MX65X
Thanks,
But at that Price, I Will give it a try after my free 30 days trial.
LD
