Restricted Software
Restricted Software
Hi All!
I created this Apple Script to look for applications and quit them if found. Currently I am running it from our directory controller, JumpCloud every 20 seconds and it seems to be working successfully. I thought I would share. Hoping to code in an email notification on violation at some point.
tell application "System Events"
	set ProcessList to name of every process
	if "Terminal" is in ProcessList then
		set ThePID to unix id of process "Terminal"
		do shell script "kill -KILL " & ThePID
		display dialog "This application is restricted. Please submit a ticket if you have legitimate need for this application"
	end if
end tell
Thought I would share if anyone else is looking for something similar,
Jared
1 REPLY 1
Re: Restricted Software
		display dialog "This application is restricted. Please submit a ticket if you have legitimate need for this application."
		tell application "Mail"
			set theSubject to "Restricted Software Violation" -- the subject
			set theContent to "Violation - Terminal Opened " -- the content
			set theAddress to "technology@flitt.org" -- the receiver
			set theSignatureName to "Automated Management" -- the signature name
			set msg to make new outgoing message with properties {subject:theSubject, content:theContent, visible:true}
			tell msg to make new to recipient at end of every to recipient with properties {address:theAddress}
			send msg
		end tell
	end if
end tell
Updated Version that sends email notification.
