Remote Management Cancelled
We are using apple configurator 2.10 to add these iPods into DEP, which we have had no problems in the past. I see them in Meraki Systems Manager MDM assign the profiles as normal. But, when I go through the setup and get to the Remote Management Screen, where it says "company name" will automatically configure your iPod touch. When you hit next instead of pulling the config like it has done in the past it immediately says cancelled. Has anyone run into this before? This just started happening within the last week or so.  Thanks!
1 REPLY 1
Re: Remote Management Cancelled
It sounds like you need to open a support case.
