Push iOS updates without user intervention
We're looking at pushing iOS updates out through Systems Manager (iOS devices are DEP / Supervised) unattended - no manual intervention.
Currently it looks as though we can trigger the download of the iOS to the device, although the user needs to click OK to install it. Is there a way of no manual intervention at all and installs the OS automatically once it has downloaded
Is System Manager Capable of doing this?
Cheers, M
Accepted Solutions
Re: Push iOS updates without user intervention
I believe the only way for the update to go through is if the device doesn't have a pass-code or fingerprint set to unlock
1 REPLY 1
