Just curious to see if anyone else is having issues with profiles copying over between networks. This has always worked in the past up until the recent changes in Dashboard.
No I don't mind re-adding all of the setup I have done in the other network but I'd much rather it just work as intended. I have opened a case already but thought I would see if anyone is experiencing this behavior.
Solved! Go to Solution.
I just noticed the same thing today.
Profiles with Wifi Settings seem to work but profiles with iOS Restrictions will not copy.
@MikeMandalorian I'm sure hoping it's a bug, because if this is now the "new" version is going to work. I want the old one back. I much rather would be able to copy profiles then having to build them by hand for every single network when we make a change.
@PatrickL I just tried it again and received the following message.
I just tried it again this morning and the profile copy is working correctly.
