Dear Community,
is there any way to get Owners imported / synced with Azure AD? I found the article ( https://documentation.meraki.com/SM/Device_Enrollment/SM_Enrollment_Authentication ) that describes the integration with an on premise AD. Also, I got the Azure AD integration running for the administrative access ( https://www.geekshangout.com/meraki-saml-single-sign-on-with-azure-ad ).
Is there any way to achieve the same for the owners?
Regards, Flo
Solved! Go to Solution.
You don't so much as import or sync owners - but the devices can authenticte against Azure AD, and then you see those owners in the Systems Manager portal.
We set it up using the first link you supplied. We have only used it with modern Android devices.
Hi Philip,
thank's for the hint - integration works well and users from AD show up in the "Owners" list. However, now we're not able to setup the Windows 10 MDM integration - seems to be something related to that change... But as far as I understand you, you only manage Android devices!?
Re, Flo
I have a couple of Windows 10 machines we use it with as well. They work ok.
Do you use the agent and MDM integration?
