Meraki Systems Manager msi not installing under GPO software installation
Trying to deploy Meraki Systems Manager through group policy on Windows Server 2008 R2 to Windows 10 desktops. I've confirmed that group policy works for other msi files, checked share permissions and security permissions with Everyone and Authenticated Users set to full control (more than enough to allow other software to install) on the network share, turned off UAC prompts, but Meraki will not install this way. It deploys fine manually on the systems. I've also followed the step by step guide Cisco has for deploying Meraki through AD and group policy to no avail. Any help or ideas on why this fails would be appreciated.
Thanks,
Steven
2 REPLIES 2
Re: Meraki Systems Manager msi not installing under GPO software installation
What's the event log on a client say? Did you confirm on a client with RSOP.msc that the GPO is applying?
MRCUR | CMNO #12
Did you get this resolved? I've deployed this via GPO but the clients then aren't appearing in Devices on Meraki.
To deploy it, I deployed via the Computer and not the User.
