Search instead for
Meraki System Manager has been really slow the last week or so
Has anyone notice Meraki System Manager has been really slow the last week or so ?Both the console and setting up devices.
We are using ipads with DEP and when setting up new devices once you get to the ipads home screen usually Apps and profiles start pushed down from Meraki within a minute. This last week it take anyway where from 10- 20 min or more before Apps and profiles start to install.
Has anyone else experienced this ?
Accepted Solutions
Re: Meraki System Manager has been really slow the last week or so
Yeah definitely back to normal now.
I just heard back from Meraki support as well and they said the issue is fixed.
6 REPLIES 6
We have seen a delay in setting up iPhones in the past week.  Maybe your issue and my issue are related.
https://community.meraki.com/t5/Endpoint-Management-Systems/Meraki-HTTPS-traffic-to-SM-clients-incre...
Yes - same experience  here.
Haven't had this issue in the ~3 years I've used SM.
Triggering the activation in Apple Configurator 2 before handing the user the iPad has helped. I have noticed this delay also.
Looks to be back to normal now!
Thank you,
Peter James
You resolved the Thread before your rumour mill could start Smiley Happy
