Meraki MDM Adroid Proxy Settings
MichelRueger
Hi All does any Body know if there is a way to push Network Proxy settings to a Adroid Device? If I add a WLAN Profile there are Proxy Setting but the Info Button shows only for IOS Device! Stange is that all other MDM Software Solution are able to do so? Is there a other way to push this Infos to the Device?
2 Replies 2
DensyoV
It is only supported by Apple devices at the moment. Unfortunately, there is no other way of pushing proxy settings via Meraki MDM.
Thanks,
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
MichelRueger
I am Sorry but if I testet it with MobileIron, SOTIS, Samsung Knox and it works perfect so it is definitely a Meraki MDM problem.
