MacOS and Windows enfornce system firewall
Is there MDM setting for MacOS and Windows to make sure the default system firewall is turned ON? I simply cannot find it
thank you
4 REPLIES 4
Re: MacOS and Windows enfornce system firewall
I know for Mac OS youc an force filevault and firewall via a configuration profile. I am not sure about Windows.
Where is the setting located for Mac OS? I can't find it in any of the available options.
Also can't find it for Windows, but our Windows systems can at least have it enforced via GPO.
I highly recommend buying Apple's Server app for $20. You're able to create custom profiles and the Profile Manager section has additional templates that Meraki does not offer.
That being said, I have a custom payload that enforces the firewall you can use 🙂
https://bazaarvoice.box.com/s/nfrkdo2gz3tplcgxqgtxoqvxweqdreaj
Here is the policy in case anybody is interested
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
	<key>PayloadContent</key>
	<array>
		<dict>
			<key>Applications</key>
			<array>
				<dict>
					<key>Allowed</key>
					<false/>
					<key>BundleID</key>
					<string></string>
				</dict>
			</array>
			<key>BlockAllIncoming</key>
			<false/>
			<key>EnableFirewall</key>
			<true/>
			<key>EnableStealthMode</key>
			<false/>
			<key>PayloadDescription</key>
			<string>Firewall Payload</string>
			<key>PayloadDisplayName</key>
			<key>PayloadIdentifier</key>
			<string>com.apple.security.firewall</string>
			<key>PayloadOrganization</key>
			<string></string>
			<key>PayloadType</key>
			<key>PayloadUUID</key>
			<string>2c446a50-e683-0135-c0eb-0c85903e08f9</string>
			<key>PayloadVersion</key>
			<integer>1</integer>
		</dict>
	</array>
	<string>Required firewall enforcement</string>
	<string>Firewall enforced on client</string>
	<string>com.apple.security.firewall.pci</string>
	<string>Your company Inc.</string>
	<string>Configuration</string>
	<string>c9fe66c3-5292-4298-aa54-006fcd59bfdf</string>
</dict>
</plist>
