Lock screen on Android pad.
Jan
I have been looking, but cannot really find a way to either disable the lock screen on Android devices, or to adjust the time it takes before the device locks the screen and turns off the screen.
As it is now the devices power button must be pressed briefly to awake the device.
Have tried to create a policy for this, but not found a setting for it.
BR
Jan
BlakeRichardson
@Jan from what I can see looking at the available settings for Android this is not possible on Meraki. Most of the MDM settings relate to iOS there are very few settings for Android.
2 Replies 2
BlakeRichardson
Hi. Yes, that is my observations as well. Just had to ask in case I missed something. Thanks!
