Is there a way to block Messages and Safari on macOS?
We're piloting a few macbooks in our org and we want to block Messages and Safari from being used. Does anyone know of a way to do so? I can only find a way to do so on iOS devices, no macOS.
Accepted Solutions
Re: Is there a way to block Messages and Safari on macOS?
Was able to block using Santa by Google.
4 REPLIES 4
Or even use the Firewall to block incoming connections on those apps?
Running apps policy blacklist?
Thanks for the suggestion. I've set up a blacklist and applied dynamic security policy tags, but it seems I'm still able to open them. The blacklist, that I can see, only shows if they're in violation of the policy, not actually blocking the app. I'm brand new to Systems Manager (literally today) and it's a bit hard to navigate and understand the settings, so I may be doing it wrong.
