Search instead for
How do you enroll an iOS device into DEP?
Trying to enroll via DEP my devices to have them “supervised” but can’t seem to make the Assigned status tu pushed. Any help would be appreciated
Accepted Solutions
Re: How do you enroll an iOS device into DEP?
It's worth noting that DEP settings for iOS devices are only applied at time of activation. An iOS device would have to be either new or erased/wiped then (re)activated for the settings to be applied.
There's a Meraki documentation article about DEP, with a couple videos that help walk through the process both on the Dashboard and on an iOS device.
1 REPLY 1
