Search instead for
Errror SSL 5
Errror SSL 5
Hello today all my osx recibe error SSL =5 from 11:00 GMT+1
Yesterday all working correctly, all have last version 1.0.98
Is a server error?, i test with other conectivty , and show same error
2019-01-18 17:25:24.883480 [0x70000a9ab000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], r < 0, ERR_get_error = 0
2019-01-18 17:25:24.883629 [0x70000a9ab000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], r < 0, errno = 32
2019-01-18 17:25:24.883684 [0x70000a9ab000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], unexpected SSL error 5 after SSL_connect() returned -1
sigpipe_handle
2019-01-18 17:26:06.532810 [0x70000a9ab000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], r < 0, ERR_get_error = 0
2019-01-18 17:26:06.532973 [0x70000a9ab000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], r < 0, errno = 32
2019-01-18 17:26:06.533021 [0x70000a9ab000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], unexpected SSL error 5 after SSL_connect() returned -1
2019-01-18 17:27:03.405934 [0x10b13c5c0]: ClientManager::check_client_pulse(): client pcc199.meraki.com:993 timed out; restarting
Accepted Solutions
Re: Errror SSL 5
You need to open a ticket with support.
When I nmap scan node pcc198.meraki.com port 993 is open.  So I think something is wrong with node pc199.
Re: Errror SSL 5
Is the date/time on your machines roughly correct?
Re: Errror SSL 5
Hello
yes, all machines have time server.
And now I'm into one machine with same error into m_log, and the date and time correct.
2019-01-19 11:33:49.345887 [0x700005f4e000]: TunClient::main() [pcc199.meraki.com:993], starting up...
2019-01-19 11:35:10.31497 [0x700005f4e000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], r < 0, ERR_get_error = 0
sigpipe_handle
2019-01-19 11:35:10.32648 [0x700005f4e000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], r < 0, errno = 32
2019-01-19 11:35:10.32729 [0x700005f4e000]: TunClient::connect_to_proxy() [pcc199.meraki.com:993], unexpected SSL error 5 after SSL_connect() returned -1
2019-01-19 11:35:56.807704 [0x118cd25c0]: ClientManager::check_client_pulse(): client pcc199.meraki.com:993 timed out; restarting
sigusr1_handle
2019-01-19 11:35:57.910750 [0x700005f4e000]: TunClient::main() [pcc199.meraki.com:993], starting up...
I test NMAP and not show port 993 open
MBP-WS-AA03231:~ albert$ nmap pcc199.meraki.com
Starting Nmap 7.70 ( https://nmap.org ) at 2019-01-19 11:36 CET
Nmap scan report for pcc199.meraki.com (209.206.58.14)
Host is up (0.031s latency).
rDNS record for 209.206.58.14: fra167.meraki.com
Not shown: 996 filtered ports
PORT      STATE  SERVICE
80/tcp    open   http
443/tcp   open   https
60020/tcp closed unknown
60443/tcp closed unknown
Re: Errror SSL 5
