I have a problem with import students and groups into Education Configuration.
All students and groups are defined in ASM and imported to Meraki System Manager.
After check "Use ASM" (see screenshot) all group are loaded, but without users and user names (only hex ids?).
It is impossible to save configuration, nor changes in group.
This error mesage ocures:
There were errors in saving this configuration:
What is wrong? Is it a bug?
Thank you
PS: Manual configuration without "Use ASM" checkbox works fine without problems. But double definition hundreds of students to all classes will be silly.
@JanNovak Mine looks the same but when I look at owners it shows the correct names.
What do you see when you look at owners?
All changes in groups need to be made in ASM to import into Meraki, you cannot change groups within Meraki if you are importing the groups from ASM.
Yes I know, I try change only one editable field "Description" in "Edit group" and click save, nothing happen.
Imported users from ASM in owners section looks fine.
I have also one theory, because managed Apple ID's are defined without appleid. prefix in domain (simple school email) and it could couse something?
Thank you
You may want to check the DEP settings then. If you aren't adding a prefix to your users when you create Apple IDs you want to make sure you aren't stripping anything off of them.
It is also OK, Managed Apple IDs was created without prefix and "Strip prefix" is not checked.
