Duplicate iPads
Just browsing
Duplicate iPads
We have several duplicated iPads in our Meraki Systems Management console. It seems to be be treating a DEP device and an iPad enrolled via web-browser as two different devices? Is there any way to merge the two devices?
We have 43 iPads but 58 are showing due to duplicates which looks to be causing grief with licenses. I can see serial numbers duplicated in the lists.
Any help appreciated.
Thankyou,
Michael
5 REPLIES 5
Re: Duplicate iPads
that shouldn't happen. We have DEP enrolled devices which I've removed from Meraki and then re-installed manually and never had them duplicated.
I suggest contacting Meraki support
Re: Duplicate iPads
I would just end up deleting the duplicates and re-enrolling them. I don't know why they would be joined twice by DEP and the web browser.
Re: Duplicate iPads
 i had that happen in the past but it was My error not Meraki or DEP,, if i had a managed device that needed to become supervised  and if I forgot to remove it from the console first before enrolling it to then re add it as supervised  . Then i would have a duplicate
Re: Duplicate iPads
@Mike_YMCAMIDTN  that has even happened to me as well which is why I asked @WPS-IT if by chance this might be it.
Re: Duplicate iPads
I would have thought the backend would be smart enough to know a device with the same serial and MAC is a duplicate.....
