Custom Android App Showing in Kiosk Mode
I am having problems getting the custom apps I have add to show up in kiosk mode. I know that the apps have been added correctly because they are showing up in the managed apps and on the tablet outside of the kiosk mode. How ever when ever I go into kiosk mode I get this error on install. Below in the first picture is what I see in kiosk mode the second is the list of managed apps showing that they are properly configured and the is the error I am getting.
Any help would be great
2 REPLIES 2
Re: Custom Android App Showing in Kiosk Mode
What is the specific version of Android you are using? Have you tried this out on a different version of Android (e.g. 9 vs 10)? What version of the SM app are you using? Tell us the hardware type as well, but that is less likely to be the issue.
Android version - 9 (currently the highest software version for the tablet)
SM version - 5.2.8
Hardware - Android Galaxy Tab A 8
I think the problem lies here. That is purely base on the fact that When I added the app it installed on the tablet just fine. But when in the kiosk mode it is not wanting to show up.
