Configuring Apple Classroom for iPads
Attempting to setup Classroom via Meraki but keep getting this error when opening the Classroom iOS App when logged in as 'Teacher'.
"Classroom must be configured with a valid education configuration profile"
I have deployed an educational profile to all iPads:
Any help would be appreciated!
Thanks.
6 REPLIES 6
Re: Configuring Apple Classroom for iPads
This was something I found doing some research. Hope it helps. 🙂🖱
  1. Are the students IPad supervised?
  2. Is bluetooth enable on both the students and the teachers devices?
  3. Is the network capable of device to device communication?
  4. Are the device on the same subnet?
Hi! Thanks prompt for the reply.
  1. Are the students IPad supervised? Yes, the student & teacher iPads are supervised.
  2. Is bluetooth enable on both the students and the teachers devices? Yes, the student & teacher iPads have bluetooth enabled.
  3. Is the network capable of device to device communication? Yes, the network allows this.
  4. Are the device on the same subnet? Yes, iPads are on the same subnet.
@intensify Right now I'm on the phone with Meraki support as I am having issues with the Classroom profile installing onto the iPads. I am getting the following error.
Code: 1000
Domain: MCProfileErrorDomain
Error: The profile “Apple School Manager - Classroom” is invalid.
Error: The payload “Apple School Manager - Classroom” is invalid.
Error: A group with the beacon ID “40” already exists
Are you seeing any errors when the profile applies?
@alexis_cazalaa Thank you for that link, this school year has been so crazy, I've been absent and not up to date on the community.
@intensify I see you did not check the box for using ASM to send information, was this intentional?
I would highly recommend using ASM to manage your users and not Meraki.
