Hello all
New user, I have enrolled new clients, but they are not showing on the dashboard.
Am I missing something simple?
Thanks.
Andrew
How are you enrolling the devices? Do you see the SM profile installed on the device? You should see newly enrolled devices in Dashboard almost immediately.
Hello MRCUR
Just using the safari on the iphones with the code shown on the meraki screen.
Not showing in the dashboard. waited a while, software on/off, re-boot, has not shown.
This is now the second device that has not shown.
And yes, the app is showing on the phone, showing connection, but not showing in Meraki.
Disappointingly yours, Andrew
We're seeing the same issue with the legacy PC msi client install.
Downloaded the latest MSI from the systems manager page, but none of the new PCs are showing in the dashboard
@AndrewS Just to confirm - if you go to Settings -> General -> Profiles, do you see the Meraki profile there?
Hello, yes, I have created a profile, but the newer devices were set up using safari and the code that Meraki gave, but are still not showing.
