Search instead for
Can't Setup Device due to a Checksum error
Hi All.
Just trying to setup a google pixel phone and I'm getting the following error
Cant setup device
Couldn't use the admin app due to a checksum error.  For help contact your admin.
Anyone have any suggestions why.  The device is a google pixel running Android 8IMG_0011.JPG
1 REPLY 1
Re: Can't Setup Device due to a Checksum error
Hi Mark,
It looks like meraki has updated one of the packages required during the installation.  However, it looks like the haven't updated the checksum in the QR code to match the new apk files.
I had to:
     create a new network
     get the qr code
     unencode that qr code with the correct checksum
     unencode the old qr code/ get my meraki network id
    put the correct network id with the correct checsum in a text string
   use an online encoder to create the correct QR code.
I have raised a support ticket with meraki, found the problem and  then advised them, so hopefully they will fix it soon.
Good luck
Cheers,
Jay
