Block Guest WiFi
Block Guest WiFi
Have a problem with users connecting to a guest wifi on a managed device?
Saw this on another form and thought it was a neat work around ~ push out the wifi SSID, disable auto-join, and put in a random & wrong password! Device won't join the wifi and user does not have the option to override it.
3 REPLIES 3
Re: Block Guest WiFi
Yep, we do that here to keep student devices off of the guest network and on the correct SSID for their iPads.
If it's a supervised iOS device, you can also use 'Enforce Wi-Fi whitelisting (iOS 10.3+)' in the restrictions payload to limit users to only connect to SSIDs pushed down by SM! One tip with this would be to configure a backup SSID to be used only as backup in case the primary goes down or is unreachable so that the device isn't stuck offline.
@PatrickL I did see that restriction. I wish Apple also gave admins the option to do a whitelist/blacklist for WiFi networks.
