Search instead for
Apple Classroom for Mac.
Is anyone using Apple Classroom for Mac with Meraki Systems Manager. I am trying to test it out with an already setup macbook. My specific question is do you have to go through DEP and original setup to enroll macbook, or can you use the Systems Manager Agent or m.meraki.com to get the macbook into Meraki & install the education profile on the macbook?
5 REPLIES 5
Re: Apple Classroom for Mac.
I think you can do it without DEP following the instructions on this page:
https://documentation.meraki.com/SM/Device_Enrollment/Mac_Enrollment
That said, keep in mind this note:
For school-owned iOS devices, it is highly recommended that administrators use Apple School Manager and Device Enrollment Program (DEP) whenever possible. These programs allow an administrator to enforce mandatory device supervision, customize device setup, and automate enrollment into Systems Manager in bulk. This means administrators can pre-configure devices online even before they arrive on site, and these devices will enroll in SM out of the box during the setup assistant, without having to first physically configure the devices.
Source:
https://documentation.meraki.com/SM/Deployment_Guides/Education_Deployment_Guide_and_Best_Practices
One caveat of using Apple Classroom for Mac is that you must deploy the profile on a per user basis rather than per device like with iPads. I experimented with this when Apple Classroom for Mac was first introduced and this ability was not well known but I believe Meraki has addressed this issue. I haven't tried getting it to deploy to a MacBook though.
If you don't use DEP then you can't do a lot of things automatically - the user will get prompts and they will have to give permission.
Thanks.
Yes, I have found the same issue, but haven't found a way to deploy the profile on a per user basis yet.
I am still unable to get the education profile onto the macbook even using DEP. The macbook gets the management profile from Meraki, but does not get the education profile. I have tried putting a tag on the owner so the education profile would go to the user and not the device but still have no luck. I get the following messages.
Domain: ClassroomMCXService.installError
Error: Installing EDU profiles using the device channel is unsupported.
It is the education profile that the iPads receive. Any help would be appreciated.
